DAX Exercise for fun 😁 Part 2
Here is your data:
Dax Problem 2.pbix (17.2 KB)
You need to create a Calculated table that Unpivots the data using DAX:
Have fun! Make sure to blur your solutions.
Edit 1:
@DavieJoe’s solution made me realize I should make it a little difficult by adding a caveat. Now you can’t use SUMMARIZE or SUMMARIZECOLUMNS or any other projection function.
Edit 2:
@DavieJoe and @BrianJ are exempt from this but if you try to solve this problem then don’t use projection functions.
Hint: Use Context Transition, I want you to think more about a way to solve this using Context Transition.
You’re trying to destroy what is left of my brain @AntrikshSharma :exploding_head::exploding_head:
This might not be the most elegant of solutions
UNION(
SUMMARIZECOLUMNS('Table'[Index], 'Table'[Col 1]),
SUMMARIZECOLUMNS( 'Table'[Index], 'Table'[Col 2] ))
Nicely done and pretty quick looks like I need to increase the difficulty a little bit, to make people think a bit more… :smirk:
Hahahahahaha, changing the rules afterwards :joy::joy::joy::+1:t2::+1:t2:
Hehe
After @DavieJoe’s solution:
tenor
@AntrikshSharma ,
I have a feeling #2 was intended to lull us into a false sense of security. I suspect #3 is going to be a doozy… :smiley:
Wow this post turned out to be bit bad Lol. I should have made a caveat earlier about projection functions :dizzy_face: :sob:
Hi @AntrikshSharma,
How’s this…
T0 =
UNION(
    ALL( Data[index], Data[Col 1]),
    ALL( Data[index], Data[Col 2])
Don’t know if ALL is allowed and yes,
also had SUMMARIZECOLUMNS, SUMMARIZE and SELECTCOLUMNS ready to submit :upside_down_face:
@Melissa Good one! I will alow everything now, but will wait if someone gets a solution with Context Transition, not because it is a complex way of doing the same thing but just want to push their limits :stuck_out_tongue:
@AntrikshSharma reviewing the solutions submitted so far…:
flip
@BrianJ My reaction after each solution:
It’s great to see so many different ways to create this table!
Also great to see @AntrikshSharma’s brain go :exploding_head: :joy::+1:t2:
Don’t worry @Melissa …… @AntrikshSharma will just change the rules anyway :joy::joy::joy::joy::joy:
@DavieJoe haha, me to anyone giving a solution that I don’t like:
@AntrikshSharma ,
Is this more what you were looking for?
Hey @AntrikshSharma
Here goes the solution
Table =
UNION
This text will be blurred(
SELECTCOLUMNS(Data,“Index”,Data[index],“Value”,Data[Col 1]),
SELECTCOLUMNS(Data,“Index”,Data[index],“Value”,Data[Col 2])
@BrianJ I was looking for something like this:
Table =
GENERATE (
    DISTINCT ( Data[index] ),
    UNION (
        CALCULATETABLE ( DISTINCT ( Data[Col 1] ) ),
        CALCULATETABLE ( DISTINCT ( Data[Col 2] ) )
But overall all good solutions.
@AntrikshSharma
After posting the solution here i saw your post on linkedin. I saw you wrote context transition there though you have written the same here in notes too but i missed it while reading.
Here goes another way of doing it with context transition.:wink:
Table 2 =
UNION(
ADDCOLUMNS(VALUES(Data[index]),“Value”,CALCULATE(MAX(Data[Col 1]))),
ADDCOLUMNS(VALUES(Data[index]),“Value”,CALCULATE(MAX(Data[Col 2])))
