I seem to be having an issue with my date slicer. For some reason, it defaults to the American format (MM/DD/YYYY).
I’ve looked online in the forums for solutions to fix this and the only suggestions that come are changing the browser language and locale which I have done, however, the date slicer still will not change.
Since changing the browser language pack, the Data Updated section shows the correct format but the slicer does not (see screenshot)
Q: Did you check the date format in the date column and made sure it’s set to dd/MM/yyyy
also
The issue can be caused by a combination of the settings in the Power BI Service and settings in your browser. Seems you’ve already checked the browser but did you also check the Power BI service? 1) Click on the gear icon in the top right corner 2) Click on Settings 3) Select Language 4) Select Default Browser Language
I’ve created a similar situation that you’re facing in your browser. Firstly, I have attached below the screenshot of the date slicer under the “MM/DD/YYYY” format.
Now, below are the steps provided that you’ll be required to perform to convert the date slicer format from “MM/DD/YYYY” to “DD/MM/YYYY”.
Step 1:In the Google Chrome, click on the 3 dots ellipses and go to the "Settings menu. Below is the screenshot provided for the reference.
Step 2:Under the search bar, type “Languages”. Below is the screenshot provided for the reference.
Step 5:Click on the 3 dots ellipses adjacent to the language newly added and select it as you default language. Below is the screenshot provided for the reference.
Now, go back to your report and refresh it, if required, and you shall the the “DD/MM/YYYY” in your date slicer. Below is the screenshot provided for the reference.
Hoping you find this useful and helps you to convert the date slicer in the desired date format that you’re looking.
Maybe, you can put up the steps that you had to do. It might help the rest of the group if someone else has the same issue that you encountered.
thanks
Keith
I selected English UK as there was no English Australia and also made sure that the language in regional settings in Windows (See @Keith post above) was set to English Australia
