I have not followed the very latest changes but I am building a data model and am trying to create the usual “Key Measures” folder to keep all the measures in one place. However, I am not able to delete the single column that exists in the table so that the folder turns to key measures folder and as such it appears as a table in my model. Have there been some changes recently that I have missed?
Thank you, @Greg. Are you using an old file? I have it in my other files and it is fine. However, building this new data model is not showing me the option. Here is a screenshot where the delete option is not available.
See if you can delete the empty column under the key measures. If you can, then it is definitely something wrong my desktop version so might reinstall it.
You don’t have to delete that column…
Just right-click and ‘Hide’ it, then it will also show up as a Measure table once you’ve clicked Show/Hide Fields pane
Thanks, @Melissa. I did that too but the shape of the group still looks like a table as opposed to what usually happens and it changes to measure icon.
Something is up with your measures table … I created a new measures table [Key Measures 2] and everything worked properly … still can’t see the delete option for your existing [Key Measures] table … go figure …
