I want to build a slicer that can filter months for me in any years.
What I want to do is, I want to create a button or slicer with one click it can filter for me the months.
Example:
This month - Aug 2021
So with one button on the slicer will filter for me Jan - Aug month only. So that I can see all the Jan - Aug sales in 2021, 2020, 2019, 2018 … etc
Next month - Sep 2021
So the slicer will filter for me Jan - Sep month only. I can see the all the sales from Jan - Sep in 2021, 2020, 2019, … etc.
Yes, this is what we refer to as a period slicer. Here’s a video from @JarrettM on how to set that up.
Also, this is a technique that Jarrett uses in many of his Data Challenge entries. If you look in the Data Challenge Showcase, and look for his reports, you will find a number of his PBIX files you can download and see exactly how he set that up.
@Amirul - you can find them in the Data Challenge Showcase section of the portal, but in scanning through them tonight, I wasn’t able to find one where he actually used it in the same way you are looking for.
I think these might be more relevant for you. In the first one in particular, @JarrettM incorporates a great version of the period slicer that demonstrates a wide range of custom date period options.
I think this should give you what you need to fully implement this in your report, but if you have any problems, give me or Jarrett a shout.
Hi @Amirul, did the response provided by @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @Amirul, we’ve noticed that no response has been received from you since Sep 15. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Amirul, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please create a new thread.
