I have created a dashboard for manufacturing department in Power BI. It has two dates per item - Scheduled Start Date and Start Date in the same table. I have a measure which gives me the difference between schedule start and actual start date in days.
I also created another measure using if formula if it started on time using IF function. (IF SCHEDULED START DATE = STARTED DATE, TRUE, FALSE)
However, I need a count of the times it started on time. i.e. If the STARTED ON TIME = TRUE, it started on time and if itâs FALSE, it got delayed.
Can someone guide me on the best way forward to count this and display on the table?
Thanks,
Hi @Nupur, a response on this post has been tagged as âSolutionâ. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Also, weâve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
Hi @BrianJ, Thank you for providing the response.
I tried the above formula, but it gives the total count of both TRUE/FALSE. I need the count of just the TRUE ones.
Could you please help.
Thanks,
Nupur
I suspect the problem is with your [Started on Time] measure. I think the condition should be if start date <= scheduled start date then true, otherwise false ( rather than as you have it only triggering true if the dates are equal, which may not occur within the dataset). If that doesnât solve the problem, please provide a sample dataset/PBIX and we can work out where/why things are going sideways.
Itâs great to know that you are making progress with your query @Nupur. Please donât forget if your question has been answered within the forum it is important to mark your thread as âsolvedâ. Also, weâve recently launched the Enterprise DNA Forum User Experience Survey, please feel free to answer it and give your insights on how we can further improve the Support forum. Thanks!
