Conditional Formatting by Row
How can we do conditional formatting by row not by columns?
Forum.xlsx (10.2 KB)
In this image we can see the different of conditional formatting.
@Amirul Amirul.pbix (19.0 KB)
Use RANKX
Hi @Amirul, did the response provided by @AntrikshSharma help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Amirul, we’ve noticed that no response has been received from you since the 31st of March. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Amirul, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
