Combining files from Sharepoint
I am getting the above error while trying to combine files from sharepoint, Is anyone else facing the same?
I have seen that many others are experiencing this as well, but is there any work around
Hi @Anu
This is caused due to 2 reasons, either your url is not correct or you’ve limited access.
Please refer the below steps:
I am able to connect to the sharepoint site, and I am able to see all the files in sharepoint.
But when I am filtering out the required folder and clicking the “Combine”(double arrow) button , I am getting this error, Could you please check as well , as many are facing the same issue, is it something to do with the latest version of pbi
Hi @Anu,
I will also try it on my laptop where I use the february version. In my organizational environment we don’t have that version yet, but it will be installed in days. If this version has an error in combining files from SharePoint, I will advise against the installation. Are there more users of this forum with many SharePoint solutions like described above within their organisations? If so please check it too please if you find the time. :slight_smile:
Daniel
I am not sure though if it is something to do with the version of PBI
It was a problem with the February update. I installed the Dec version and its working fine
To the contributors of this post, thank you for all your inputs on this topic we are now tagging it as Solved. To help us learn more about your experience in the forum, please take a moment to answer this short forum survey. We appreciate all your help and suggestions. Thanks!
Does anyone know if this is fixed in March update?
Hi @Anu , just a friendly reminder, if your original question has been answered within the forum it is important to mark your thread as ‘solved’. If you have a follow question or concern related to this topic please start a new topic. More details can be found here - Asking Questions On The Enterprise DNA Support Forum.
