We have requirement for YoY analysis. I don’t see appropriate Clustered stacked column chart in Power BI?. Do you guys have any thought?
This is not a standard visual type that’s currently available in Power BI, although the suggestion to add it has been made on the Microsoft Community.
https://ideas.powerbi.com/ideas/idea/?ideaid=db76a137-4324-4d6c-b5c5-cb85f9b6950a
If you are willing to use custom visuals, there are number of visuals including the one below that may fit the bill:
If custom visuals are not an option, you can produce this kind of chart pretty straightforwardly in R using the ggplot2 package, and bring that into Power BI as an R visual type.
I hope this is helpful.
- Brian
Hi @rush2bi, thanks for posting your query in the Forum. If there is any feedback you would like to share so we can improve the community here, please feel free to answer our Enterprise DNA Forum User Experience Survey. Thanks!
Thank you Brian. I will try this option and let you know if I have any questions.
Hi @rush2bi, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box. Thanks!
