I have created a measure that calculates the time lapsed between a customer purchase using DATEDIFF formula. I now want to write a measure that will return the TOTAL average of all customers. IN essence I want to know the overall average of all the averages.
you would want to use AveargeX to iterate over your customers table, with your average measure as the expression. Would be easier to show if you can upload your pbix file
it says the file is too big
How can i share the file. The AVGX formula did not work. it returns a value of zero.
Have you had a chance to review many of the videos and tutorials on AVERAGEX?
https://blog.enterprisedna.co/tag/averagex/
Using AVERAGEX is a very efficient way to complete any averaging in Power BI. Highly recommend understanding this function well.
See here for some initial theory on AVERAGEX
http://portal.enterprisedna.co/courses/mastering-dax-calculations/lectures/2399489
Here’s another good tutorial to review
Also for tips on adding a pbix file in the forum see here
Hi @nikahafiz
Please start a new topic as this posting is already solved. This way your question will be answer more quickly in the forum.
Also, please don’t forget to attached your power bi file and results you are expecting
Don’t forget to delete your posting here
thanks
Keith
