I would like to know how bulk find and replace works. So in the PowerBI file that I have attached, there are two tables: ’ find and replace’ and ‘inventory table’. I want to have a new column ‘Bin category’ in my inventory table, which ought to be based on the Bin category column in the ‘find and replace table’ . I know that I can achieve this by using related function by joining the two tables, but I would like to use bulk find and replace please. Find and replace table.xlsx (8.9 KB) Inventory report.pbix (27.6 KB) inventory table.xlsx (9.0 KB)
It is not working. The M code just turns red and I am unable to run it. Also, the new column ought to be “Bin Category” not bin location, I think the code replaces values in the existing bin location column.
You described your query as “find and replace” so yes the initial solution does a lookup on Bin Location and replaceses that value with the Bin Category (if found). But the attached file also included an example that adds the result as a new column. Choose whatever works best for you.
It works well now, though I am having trouble replicating the steps on my actual dataset- the data that I gave you was dummy data. So for example, if I want to go ahead with the new column approach, I am not able to insert the ‘SearchIN’ step before the ‘Source’ step.
@musa.fasih, just open the Advanced Editor window and copy it in. Note that you’ll have to update Table and Column name references in that code to match data in your production file. And don’t forget to put in a comma at the end of each line (except the last one before the IN clause).
Sorry my m-code is very weak, which is why i am still having issues.
I have tried to replicate the steps using the M code in the Adanced Editor but I am still having issues.
As shown in the image, I have inserted steps in the Stock whse Detail table, which is my main inventory table which consists of many columns, and has bin location and bin category column as well. After the navigation step I inserted the ‘SearchIN’ and then ‘ReplaceWith’, and in the m-code I replaced column and table names with the ones that I have. Then, I tried to insert the source step, replicating the m-code in the advanced editor window to include the following code:
= Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText(“Lc67FYNQDMDQXagpns1/Fg57xJ4+EVGpSve+pzFimqdPTM9MJJHGQizGSqzGRmzGTuzGQRzGSZzGRVz/iPFOhwWhJASEkhAQSkJAKAkBoSQEhJIQEEpCQCgJAaEk5HinEhJCS0gILSEhtISE0BISQktICC0hIbSEhNASEkJLWMY7/RGeLw==”, BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#“stock_code” = _t, #“Bin location” = _t])
In the final line, I replaced “Inventory code” with “stock_code”, but this step is only retrieving the values in the table from the dummy data file that you have send to me, not the data that I am working with.
Hi @musa.fasih, It’s great to know that you are making progress with your query.
Please be reminded that asking more than one question in a forum thread and asking question after question in the same forum thread around the same project or piece of development work is considered inappropriate.
You can create a separate thread for your other questions related to this inquiry so that other users can easily check the details of your queries.
