We are experiencing an issue with Power BI – page refresh. I have turned it on for a report that we have, however the page is not refreshing automatically on the Power BI app. It is a live ticket report that appears on a big screen in our offices.
Any help would be much appreciated!
Hi @r.miah7
Check out this article and make sure your report meets all the requirements.
Hello @r.miah7, just following up if the response above help you solve your inquiry?
If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
Hi @r.miah7, we’ve noticed that no response has been received from you since a few days ago.
We just want to check if you still need further help with this post?
Hi @r.miah7, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can create a new thread.
