All function does not ignore my filter
Hi, again, I have one more question about the function ALL. what I am trying to achieve is to calculate the total OOS days (out of stock) days regardless my filter selection. It is kind of YTD OOS days. I used All in my DAX, but it did not work as I expected. Could someone please help me take a look of the syntax to see what I did wrong? Basically the YTD OOS measure should be changed for a same product when I change the date slice.
Thanks!
Opportunity_test.pbix (95.3 KB)
Mike
@Mike,
Give this a go:
YTD OOS ALL =
    DISTINCTCOUNT(  'F_Instock_tbl'[Date]  ),
    F_Instock_tbl[OOS-Flag] = 1,
    REMOVEFILTERS( 'F_Instock_tbl' ),
    VALUES( D_Product_tbl[Produc_ID] )
Thanks, @BrianJ.
That works, however, it significantly impacts the performance of the dashboard. I am wondering if there is any way to do it.
Mike
@Mike,
See if this runs any faster. If not, we may need to call in the big guns on optimization (@AntrikshSharma).
YTD OOS ALL Rev =
    COUNTROWS(
        VALUES('F_Instock_tbl'[Date])
Hi, @BrianJ, it seems getting better. Thanks a lot. I will ask for more assistance if the performance becomes a real pain.
Thanks again!
Mike
@Mike,
Great - glad to help.
Even if it’s not a problem, you may want to submit this to the Optimization Lab for learning purposes.
@BrianJ, thanks Brain. That will be awesome. Did not know we have submit a ticket to Optimization Lab for learning. Will definitely do it.
Cheers,
Mike
