Aggregate values into calendar based upon start date and duration
I am struckling with creating sums of input values into a calendar.
I have data columns as follows;
Based upon start date and duration I would like to sum the staff need per month as shown below
I have tried various combinations of SUM and CALCULATE, but cannot get it right.
Sorry, i did not upload example, now done. I believe I am close, but i end up with having the sum of the two departments cyclic added up over the 12 months of first year. I cannot find out how to slice it by department and make run over the next years.
[AggregateDateSumExample.pbix|attachment]
DLNexample.xlsx (15.7 KB) (upload://qmCfoWRvYjq6NWot2mcdAd4JR8c.pbix) (74.9 KB)
AggregateDateSumExample.pbix (74.9 KB)
Hi Jca,
its really hard for members to provide a solution without looking at actual data, kindly provide your pbix file, so members can guide better.
Regards
Hi @jca, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
  • When posting a topic with formula make sure that it is correctly formatted to preformatted text </>. image
  • Provide as much contextn to a question as possible.
@jca,
Not surprised the DAX is giving you problems. I think if you go down the road of a DAX-only solution, the code is quite complex. (Even halfway around the world, I think I hear @AntrikshSharma saying "Challenge Accepted!). However, if you transform the data as follows first in Power Query, the DAX simplifies down to one short, straightforward measure.
let
    Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("PczBDcAgDAPAXfwmyEkplFmi7L9GgSp9+OOT7Q6qsInRFAVjRVkHojj0FmXK3FLngT2xDbbKvsL6/HDloh34rozCnmAHOiJe", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Start Date" = _t, DurationMonths = _t, StaffPerMonth = _t]),
    #"Split Column by Delimiter" = Table.SplitColumn(Source, "Start Date", Splitter.SplitTextByDelimiter("-", QuoteStyle.Csv), {"Start Date.1", "Start Date.2", "Start Date.3"}),
    #"Reordered Columns" = Table.ReorderColumns(#"Split Column by Delimiter",{"Start Date.2", "Start Date.1", "Start Date.3", "DurationMonths", "StaffPerMonth"}),
    #"Merged Columns" = Table.CombineColumns(#"Reordered Columns",{"Start Date.2", "Start Date.1", "Start Date.3"},Combiner.CombineTextByDelimiter("/", QuoteStyle.None),"Start Date"),
    #"Changed Type" = Table.TransformColumnTypes(#"Merged Columns",{{"Start Date", type date}, {"DurationMonths", Int64.Type}, {"StaffPerMonth", type number}}),
    #"Added Custom" = Table.AddColumn(#"Changed Type", "End Date", each Date.AddMonths( [Start Date], [DurationMonths] )),
    #"Added Custom1" = Table.AddColumn(#"Added Custom", "Duration Days", each [End Date] - [Start Date]),
    #"Changed Type1" = Table.TransformColumnTypes(#"Added Custom1",{{"Duration Days", Int64.Type}}),
    #"Added Custom2" = Table.AddColumn(#"Changed Type1", "Dates Between", each List.Dates( [Start Date], [#"Duration Days"], #duration( 1, 1, 0, 0))),
    #"Expanded Dates Between" = Table.ExpandListColumn(#"Added Custom2", "Dates Between"),
    #"Inserted Year" = Table.AddColumn(#"Expanded Dates Between", "Year", each Date.Year([Dates Between]), Int64.Type),
    #"Inserted Month" = Table.AddColumn(#"Inserted Year", "Month", each Date.Month([Dates Between]), Int64.Type),
    #"Removed Other Columns" = Table.SelectColumns(#"Inserted Month",{"StaffPerMonth", "Year", "Month"}),
    #"Removed Duplicates" = Table.Distinct(#"Removed Other Columns"),
    #"Added Custom3" = Table.AddColumn(#"Removed Duplicates", "MoInYr", each Text.From( [Year] ) & Text.PadStart( Text.From( [Month] ), 2, "0" ) & "00"),
    #"Changed Type3" = Table.TransformColumnTypes(#"Added Custom3",{{"MoInYr", Int64.Type}})
in
    #"Changed Type3"
Total Staff =
    SUM( Data[StaffPerMonth]),
    TREATAS(
        DISTINCT( Dates[MonthnYear] ),
        Data[MoInYr]
The approach I took in Power Query is a variant of the solution that @haroonali1000 presented for Problem of the Week #4.
I hope this is helpful. Full solution file attached below
ā€“ Brian
eDNA forum ā€“ Allocating Monthly Staff Solution.pbix (176.0 KB)
PS ā€“ welcome to the forum, great to have you here!
Hi Shumalia,
Thank you for the advice, example files now added to original post
Awesome, I see I missed a lot in my own simple setup, this pushed my to a new level! Thank you for the solution
@jca,
Glad to help. Interesting problem - Iā€™d never seen this exact construct before.
