A tricky dax calculation ( DDB() finance function
just a dimension table and a date table with no real relationship between the two.
one table is a list of assets with
asset#;
live in years;
live in months;
live in days
aquistion date;
end dat of depreciation
how to calculate the yearly DDB() , monthly DDB() , daily DDB()
In order to report the future monthly depreciation amount.
I found some solution on the web using calculated columns
( a column for each year ) but this is what we should avoid
when I remember well your course.
thanks in advance for looking at this problem
Roger
depreciation assets.pbix (304.8 KB)
DDB function.xlsx (53.6 KB)
Hi @Roger! We noticed that your inquiry was left unsolved for quite some time now.
Hi @Roger,
Thanks for your patience, I’ll see if I can free some time this weekend to look into your question (if it remains unsloved).
Melissa
Hi @Roger , (v2)
Interesting problem.
  • For the DDB-calculation is required: acquisition amount, salvage( 0) , life (total periods) , and every single individual depreciation period.
  • Presumably requested reports: DDB, cumulative DDB and book value over time.
Concept of a solution:
  • In my opinion, it is necessary to create a table with each individual depreciation period and date for all assets (as the individual periods are not available and a necessary input for the DDB-calculation); three tables in this case, for Days, Months and Year periods.
  • When connecting those tables with a date table and the asset table, relative straight forward measures can be generated to calculate periodic DDB, cumulative DDB and book value of the assets to generate reports.
The workout of the concept:
  • PBIX attached:
    depreciation assets v3 def.pbix (359.6 KB)
    1. Generate tables with depreciation periods and dates for every asset for every period
    (annual, monthly, daily, based upon the asset table in Power Query (see Monthly table below)
    Explanation :
  • With Power Query the original “Acquistions”-table is expanded with the given live periods (“live in months”) for each asset.
  • With the expansion a depreciation date is added, reduced with one day (Month and Year depreciation), to get the (in my opinion) correct depreciation date (see example above), additionally the acquisition date is added (period 0), to be able to add the acquisition value to the book value.
  • The required depreciation period (for DDB) is added, using the technique of creating an index per Asset.
  • The expansion is done for three depreciation periods (Day, Month, Year), tables “Daily-”, “Monthly-” and “Annual Depr”
    Used Power query code for the Monthly period table:
    let
        Source = Acquistions,
        CreateDates = Table.AddColumn(Source, "Monthly Depr Basedate", each let myDate = [Acquisition date] in if ([live in months]) >1 then List.Transform( {-1..([live in months]-1)}, each try Date.AddMonths( myDate, _ ) otherwise Date.EndOfMonth( Date.AddMonths( #date( Date.Year(myDate), Date.Month(myDate), 1), _ ))) else {[Acquisition date]} ),
        ExpandDates = Table.ExpandListColumn(CreateDates, "Monthly Depr Basedate"),
        DeprDateCalc1 = Table.AddColumn(ExpandDates, "Monthly Depr Basedate2", each Date.AddMonths([Monthly Depr Basedate],1)),
        DeprDateCalc2 = Table.AddColumn(DeprDateCalc1, "Monthly Depr Date", each if([Acquisition date] =[Monthly Depr Basedate2]) then [Monthly Depr Basedate2] else Date.AddDays([Monthly Depr Basedate2],-1)),
        LinDeprCalc = Table.AddColumn(DeprDateCalc2, "Linear depreciation", each if([Acquisition date] = [Monthly Depr Date]) then 0 else [amount] /[live in months]),
        #"Grouped Rows" = Table.Group(LinDeprCalc, {"assets#"}, {{"Asset", each _, type table [General Account=nullable number, #"assets#"=nullable text, amount=nullable number, #"%"=nullable number, live in years=nullable number, Acquisition date=nullable date, end date Depriciation=nullable date, live in months=nullable number, live in Days=nullable number, Monthly Depr Basedate=date, Monthly Depr Basedate2=date, Monthly Depr Date=date, Linear depreciation=number]}}),
        #"Index by Asset" = Table.AddColumn(#"Grouped Rows", "IndexByAsset", each Table.AddIndexColumn([Asset],"Monthly depr Period",0,1)),
        #"Removed Other Columns" = Table.SelectColumns(#"Index by Asset",{"IndexByAsset"}),
        #"Expanded IndexByAsset" = Table.ExpandTableColumn(#"Removed Other Columns", "IndexByAsset", {"General Account", "assets#", "amount", "%", "live in years", "Acquisition date", "end date Depriciation", "live in months", "live in Days", "Monthly Depr Basedate", "Monthly Depr Basedate2", "Monthly Depr Date", "Linear depreciation", "Monthly depr Period"}, {"General Account", "assets#", "amount", "%", "live in years", "Acquisition date", "end date Depriciation", "live in months", "live in Days", "Monthly Depr Basedate", "Monthly Depr Basedate2", "Monthly Depr Date", "Linear depreciation", "Monthly depr Period"}),
        #"Removed Columns" = Table.RemoveColumns(#"Expanded IndexByAsset",{"General Account", "amount", "%", "live in years", "Acquisition date", "end date Depriciation", "live in months", "live in Days", "Monthly Depr Basedate", "Monthly Depr Basedate2", "Linear depreciation"}),
        #"Changed Type" = Table.TransformColumnTypes(#"Removed Columns",{{"assets#", type text}, {"Monthly Depr Date", type date}, {"Monthly depr Period", Int64.Type}})
    in
        #"Changed Type"
    Note 1: Thankfully used the following sources for the Power Query code:
    2 Create a data model including the created three tables, the assets table and a date table
    3. Generate measures for the periodic DDB, cumulative DDB, Acquisition value and book value for the three depreciation periods (Year, Month, Day)
    DDB (monthly periods) = SUMX('Monthly depr' ,
                       if('Monthly depr'[Monthly Depr Period] = 0,  0, -- 0 = acquisition date
                                  DDB(RELATED(Acquistions[amount]),0,RELATED(Acquistions[live in months]),'Monthly depr'[Monthly Depr Period])))
    Cum. DDB (monthly per) =
    Var CumDepr = CALCULATE( [DDB (monthly periods)] ,
                filter( ALLselected('CALENDAR'), 'CALENDAR'[Date] <= MAX('CALENDAR'[Date])))
    return
    IF(ISBLANK([DDB (monthly periods)]), BLANK(), CumDepr)
    Acquisition value (monthly) = SUMX('Monthly depr' ,
                                    if('Monthly depr'[Monthly Depr Period] = 0, RELATED(Acquistions[amount]), 0)) -- period 0 = acquisition date
    Bookvalue (monthly periods) =
    Var BookV = CALCULATE( [Acquisition value (monthly)] -[DDB (monthly periods)] ,
    return
    IF(ISBLANK([DDB (monthly periods)]), BLANK(), BookV)
    Note 2: the measures can be found at measure groups “DS Annual Depr measures”, DS Daily Depr measures" and “DS Monthly measures”
    Note 3: as in two of the four measures “SUMX” is used, the measures gives correct values for multiple asset-selections
    4. A possible DDB report of monthly DDB reporting is shown below (asset 3)
    Note 4: similar example reports are made for daily DDB and annual DDB
    Note 5: the date table is limited to the dates of the years 2021 - 2032, if the live period of assets is longer, results are presented in a “blank”-period.
    Note 6 : the graphs are calculated instantly, the table requires some processing time
I hope this answer your information requirements, if you have further questions or remarks, let me know.
Kind regards,
Jan van der Wind
Thank you for the detailed solution @deltaselect! :slight_smile:
We hope this helped you @Roger. We’ve noticed that no response has been received from you since a few days ago.
We just want to check if you still need further help with this post?
Many thanks to Jan and all contributors. this is exactly what I had in mind for the calculation of the depreciation values.
very wel explained and learned a lot
kind regards
Roger
