A problem with a cumulative calculation measure
HI All
200727_ACE_Quality_Targets.pbix (356.6 KB) !
screen shot|522x281
Check.xlsx (21.0 KB)
I am struggling since 1 week on this issue and I would like to ask for your support.
I need to calculate the values of scrap over a process. In attachment you can find the PowerBI Model
  1. I Have 100 product and for each product I have “Y” Process step to produce it (let´s take as example the “product 10” – with 5 process step - see screenshot)
  2. The values (cost) of my product increase for each process step. For this reason I have to consider the cumulative cost for the scrap cost calculation
  3. The Value of my product is given by the sum of “BOM cost” + “Labour” + “Process cost”
  4. Set Up Scrap cost per one pc produced are = Set up scrap * Cumulative total cost without scrap / Batch size
  5. When I calculate the “Cumulative total cost without scrap” the calculation is correct but when I used this measure to calculate the “Set up Scrap cost” I got wrong number
PowerBI use the column of “Total cost without scrap” instead of the “ Cumulative total cost without scrap” despite I have specified the right measure
See “check.xlsx” file column “T” (the correct calculation) and column F (the wrong PowerBI Calculation) / Column U (Check wrong calculation).
I can not understand where I am mistaking.
Your help will be really appreciated
Thanks in advanced
FG
Kindly use the measure below and it will give you the correct figure based on the explanation above. I have implemented it and got the answer expected.
SetUp Scrap Cost2 =
VAR SetUPScrap = SUM(Process_Flow_Facts[TARGETSet up scrap[units/batch]]])
VAR BatchSize = SUM(Process_Flow_Facts[TARGETMin Batch size[pc]]])
DIVIDE(SetUPScrap * [Cumulative total Production cost w/o Scraps],BatchSize)
Also make the format to be 6 decimal places in order to see the result you expect
Woooooowwww….thanks a lot for the quick and effective support :-)! I really appreciate it
You are Welcome. Cheers :smiley:
