HI,
Does anyone have any experience of getting Z Scores to work via a DAX measure?
I Can do it easy enough using a calculated column however its to static that way and i want to apply filters to my table and have the z score re calculate for the filtered data.
Attached is my PBIX file its an import from my SAP data, the columns i want to filter against i have set up as slicers at the top.
I believe all my formulas for Std Dev and Mean are correct however when i filter my data table (shown by the arrow in the screen shot) the Z score doesn’t adjust to the filter, It shows the mean for all the data. but all the cards with the measure on adjust to the correct data its just i cant get the z score in the table to do the same for some reason.
Power BI Initiatives.pbix (1.2 MB)
