I would like to create a measure that shows Ytd values including periods that do not have any transactions. The measure should take the Period slicer into account
I have included screenshots of my current work book as well as shown the desired result below
The measure that I have created is:
PeriodBal = CALCULATE(SUM(AccountDetail[Amount]))
Desired Result
2021-01 2021-02 2021-03 2021-04 2021-05 2021-06 2021-07 2021-08
192.42 214.79 214.79 383.96 400.60 497.11 422.91 422.91
Hi @gfiedler, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
- Use the forum search to discover if your query has been asked before by another member.
- When posting a topic with formula make sure that it is correctly formatted to preformatted text </>.
- Use the proper category that best describes your topic
- Provide as much context to a question as possible.
- Include the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
