YOY percentage above 100
Hi DNA Team,
I need some help with this. I have calculated the YOY percentage change.
However, I want to show the result only if the percentage change its between 0-100%(positive or negative ). if its above 100% then N/M (not meaningful )should appear. Presently having above 100% showing with my data.
YoY % Total Sale Growth =
DIVIDE( [Total Sale CY vs PY] , [Total Sale LY])
Hello @Tee1,
Well you can absolutely achieve this type of result using the “SWITCH( TRUE() )” function with the logic stated as below as an example -
Measure =
SWITCH( TRUE() ,
       [YoY % Total Sale Growth] > 0 && [YoY % Total Sale Growth] <= 1 , [YoY % Total Sale Growth] ,
"N/M" )
I’m also providing some of the links of the videos available onto our EDNA YouTube channel pertaining to this topic.
Thanks and Warm Regards,
Harsh
Thanks very helpful.
Hello @Tee1,
You’re Welcome.:slightly_smiling_face:
I’m glad that you found it helpful.
Harsh
