Hi @Greg
I am trying to sort the x-axis “Month short” ascending by “Month”. However, it doesn’t work specifically after adding max and min column marks.
Daniel
Deneb X-axis sorting issue…pbix (5.0 MB)
Hi @Greg
Daniel
Calling-out a specific forum member (or members) is discouraged. It may delay or prevent a response as many forum members will disregard such posts. Nevertheless, here’s what I came up with.
To resolve your sorting issue, move the X encoding into a shared encoding block outside the layer block, and use a max-month-ascending sort block. This fixes the bars, but messes-up the rule (as it now had x encoding), so I added a dedicated joinaggregate transform to calculate the mean and added a nested layer block.
"data": {"name": "dataset"},
"transform": [
"joinaggregate": [
"op": "mean",
"field": "001_ Total sales",
"as": "_MeanTotalSales"
"layer": [
"encoding": {
"x": {
"field": "Month Short",
"type": "nominal",
"sort": {
"op": "max",
"field": "Month",
"order": "ascending"
"axis": {
"title": null,
"grid": false,
"tickCount": 6,
"ticks": false,
"domain": false,
"labelAngle": 0,
"labelFontSize": 12,
"labelColor": "black",
"labelFontWeight": "bold"
"layer": [
"name": "_MAIN_BARS",
"mark": {
"type": "bar",
"tooltip": true,
"color": "#44494B"
"encoding": {
"y": {
"type": "quantitative",
"scale": {"zero": false},
"axis": null
"opacity": {
"condition": {
"test": {
"field": "__selected__",
"equal": "off"
"value": 0.3
"value": 1
"transform": [
"window": [
"op": "rank",
"as": "windowMinMax"
"sort": [
"filter": "datum.windowMinMax ==1"
"name": "_MIN_BAR",
"mark": {
"type": "bar",
"tooltip": true,
"fill": "#c1595d"
"encoding": {
"y": {
"axis": null
"transform": [
"window": [
"op": "rank",
"sort": [
"order": "descending"
"name": "_MAX_BAR",
"mark": {
"type": "bar",
"tooltip": true,
"fill": "#269595"
"encoding": {
"y": {
"axis": null
"name": "_Mean_Reference_Line",
"transform": [
"filter": "datum['Month'] == 1"
"mark": {
"type": "rule",
"tooltip": true,
"orient": "horizontal"
"encoding": {
"y": {
"field": "_MeanTotalSales",
"color": {"value": "orange"},
"size": {"value": 3}
Hope it helps.
eDNA Forum - Deneb X-axis Sorting.pbix (5.0 MB)
Thank you so much @Greg ,That’s really helpful.
Daniel
