@qholmberg Good question and glad you want to tackle some DAX. I would suggest viewing these free and excellent courses by eDNA and @sam.mckay. These two courses got me hooked and started my Power BI and DAX journey and I haven’t looked back since.
Thank you for the reply, Paul. I’ve been through Sam’s introductory courses (as well as a couple of other content provider’s out there). I’m currently wrapping up Sam’s advanced DAX course. Additionally, I actively work with DAX throughout my work week.
What’s powerful, in my opinion, with these workouts is that it gives a specific assignment to hone skills. However, while Sam’s intro and advanced courses are powerful, I don’t recall coverage of something like highlighting a bar chart based on slicer selection. They are more based on the calculations needed to supply decisions to stakeholders (as they should be).
I would not ask that content be created on how to solve any of the workouts. That would defeat the purpose of the workouts. Rather, there is probably pre-existing content that could help someone who has the proper coursework/experience in understanding the technique so they could then apply that to the workout.
That pre-existing content is what I think would be beneficial to add as a starting point for those who might not readily see one.
@Paul.Gerber … that was just an example. It was not the only example I could have used. I searched EDNA and think I have found something that will explain it … Dashboard (enterprisedna.co)
Searches for other workouts were not so successful so I just looked at the solution and learned what I could.
These are truly amazing times we’re living in. My go-to these days when getting stuck on a problem is to fire up ChatGPT and start prompt engineering. Here’s what I fed into ChatGPT-4 for the workout you referenced and what I got back:
Then you can follow up with additional questions, such as: “but what if I want to allow users to make multiple selections in the slicer?”
The answer that ChatGPT provided, while not exactly the way I constructed my solution, is still a very viable way to go, and a great way to get started if you’re stuck.
@qholmberg not at all. You will learn from these. We are all always learning DAX. what I have found is that there is more than one way to solve a problem.
