Hi
None of the links to workouts are working.
Hi
I don’t see the workout section within the forum either. I sent an email message to Customer Support. Hopefully, they will have it correct soon.
thanks
Keith
I have the same problem. When I click on any of the workout links it says: Oops! That page doesn’t exist or is private.
Hi!
I have the same issue with the Workouts! Any news regarding this topic?
I used to check Data Visualization Workouts
FYI…i sent an email message to both Sam and Customer Support about an hour ago. They will be waking up soon in New Zealand.
Just fyi I got a reponse from CS
Dear Samantha,
Thank you for your inquiry. Our sincerest apologies for any inconvenience you have experienced. We regret to inform you that the Workouts are no longer available on our platform, hence the “Page Not Found” message.
We appreciate your interest and would recommend exploring our other resources for similar content.
Thank you for your understanding and support.
Best regards,
Anilyn
Hi EDNA,
How are you supposed to finish a learning path now that the work-outs are no longer available?
With kind regards,
Yvonne
