Working Days based on Current Fiscal Month
Hi ,
I am trying to get the total sum of Working days for the selected Fiscal Month. For Current Month, it gives 7 for Nov as Period 11 Starts on Oct 25th
WorkdaysForPeriod =
CALCULATE(COUNT(date_dimension[Date]),FILTER(ALLSELECTED(date_dimension),date_dimension[OperationPeriod] = SELECTEDVALUE(date_dimension[OperationPeriod]) && date_dimension[IsWeekend] = "0" && date_dimension[IsHoliday] = "0"))
Whenever I selected previous completed Months I do get correct number but I need to get the current month value to be 21 however I cant get it to my desired result
Please guide or Help me
Archer
@Archer
If the formula was working correctly previously then i guess that something else must have gone wrong or changed in your dataset. It would be helpful if you can share your PBIX and excel file to look at.
Sorry I am trying to develop this logic for the first time … I meant when I select previous month lets say Oct, Sep then I am getting correct Count of Working Days
Archer
@Archer
I have simplified the formula and it’s correctly pulling out working days based on month or period:
WorkDaysInPeriod =
VAR SelectedMonth = SELECTEDVALUE( ‘Date’[MonthOfYear] )
VAR Result =
COUNT( ‘Date’[IsWorkingDay] ),
FILTER(
ALL( ‘Date’ ),
‘Date’[MonthOfYear] = SelectedMonth ) )
Return
Result
I have no idea how you have set up your WorkDays but I would suggest to have WorkDays (excluding Weekends and Holidays) in Power Query rather than making it complex in DAX.
PBIX file is attached.
Working Days.pbix (111.4 KB)
Thanks for posting your question @Archer. To receive a resolution in a timely manner please make sure that you provide all the necessary details on this thread.
Hi @MudassirAli, Thank you for your help! Much appreciated
My Storage mode is Direct Query and I have a date_dimension with IsWeekend and IsHoliday flags already built into this table.
My initial DAX worked and I figured this was data model issue where I had bi-directional on with another fact table that was filtering out current months’ date to only till Nov 3rd. I have changed the relationship and ended up with two versions of working DAX.
WorkdaysForPeriod =
COUNT
FILTER(
Workdays =
VAR _WorkCount =
CALCULATE (
COUNTX
(FILTER
(date_dimension, date_dimension[Weekday] <> “1” && date_dimension[Weekday] <> “7” && date_dimension[IsHoliday] = “0” ),
date_dimension[Weekday])
_WeekdayCount
I will use your Code as well :slight_smile:
Archer
