I’m trying to locate a visual I can use to measure the time between various procurement steps. In searching Google, I’ve come across the attached visual, which I really like. Does anyone know what this is or how it could be replicated inside Power Bi?
That’s a very cool idea that I’ve never done before - you could basically set that up like a SmartNarrative-type templace and just populate the blank spaces btw the green dots with dynamic measures.
If I understand, I could make a template inside PowerPoint, then add it as an image into Power BI, then create measures using the card visual that would overlay into the PowerPoint picture?
