Hello experts,
I want to get TOP N /Bottom customers using what if parameters. But that option is grayed out for my live SSAS dataset. Is there any work around for this to solve?
Latha
Hello experts,
Latha
Hi @edna ,
From what I’ve read, live connections currently don’t support composite models like Direct Query. Since What If parameters add a table to your data model, you currently cannot do this using a live connection.
You could create a dummy table in the cube that stores the possible values of the parameter and display them in a slicer and have the user select the value they want to use.
Regards
Thank you ! I was thinking of the same but wondering any other options exist.
Hello @edna, just following up if the response above help you solve your inquiry?
If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey,We hope you’ll give your insights on how we can further improve the Support forum. Thanks!
We’ve noticed that no response has been received from you since a few days ago. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
