What are some most commonly used ETL tools with Power BI
Hi, Power BI has Power Query to do some transformations before importing data into Power BI.
What are some other dedicated ETL tools that you use for staging, cleaning data at your work?
It would be helpful, if you can explain your ETL process in detail. like sources, staging and cleaning. :slightly_smiling_face:
Bumping this post for more visibility from our experts and users.
Hi @AnilKumarPoda - There are numerous ETL tool available that can be used like SSIS, Azure Data Factory, Informatica, DOMO etc. Each one has their own function. ETL process will generally involve 2-3 stage but it can be expanded as per specific Architecture.
Staging Layer - Containing Raw Data,
Intermediate layer - Containing Merged Data,
Final Layer - For consumption into Reports.
Ankit J
@AnilKumarPoda
The easiest way to understand how ETL works is to understand what happens in each step of the process.
Extract
During data extraction, raw data is copied or exported from source locations to a staging area. You can extract data from a variety of data sources, which can be structured or unstructured. Those sources include but are not limited to:
  • SQL or NoSQL servers
  • CRM and ERP systems
  • Flat files
  • Email
  • Web pages
Transform
In the staging area, the raw data undergoes data processing. Here, the data is transformed and consolidated for its intended analytical use case. This phase can involve the following tasks:
  • Filtering, cleansing, de-duplicating, validating, and authenticating the data.
  • Performing calculations, translations, or summarizations based on the raw data. This can include changing row and column headers for consistency, converting currencies or other units of measurement, editing text strings, and more.
  • Conducting audits to ensure data quality and compliance
  • Removing, encrypting, or protecting data governed by industry or governmental regulators
  • Formatting the data into tables or joined tables to match the schema of the target data warehouse.
Load
In this last step, the transformed data is moved from the staging area into a target data warehouse. Typically, this involves an initial loading of all data, followed by periodic loading of incremental data changes and, less often, full refreshes to erase and replace data in the warehouse.
Hello @AnilKumarPoda
If not, can you let us know where youโ€™re stuck and what additional assistance you need?
Thank you
Alongside Power Query, we use tools like Azure Data Factory, SSIS, and sometimes Skyvia for cloud-based ETL. Our typical flow is pulling data from SQL or cloud apps, running transformations in the ETL tool, and pushing the cleaned data into Power BI for analysis.
