Web URL not working on a button
Good Day,
I would like some assistance regarding the following:
I want to embed a JPEG/ JSON file into a PowerBI dashboard and not have a link to the file as many have suggested. The JPEG will comprise of a few bullet points.
The JPEG will be stored on a Share Point folder. Every month, a new JPEG will be created and stored in the Share Point folder. The JPEG will be created from a word document.
So what I need is to display this JPEG in the PowerBI report and also have a Month and year filter to control which report I want to see.
Is this possible?
I am open to any platform, whether it be PowerApps, Python, etc…
Any help regarding this matter will be greatly appreciated
Hi @Akshay_05
Check this post from Brian and see if it is helpful. Here he talks about storing image as Base64 inside Power BI itself.
Ankit J
@Akshay_05 ,
Here’s how to do this:
Encode your images into Base 64 using an online converter such as this one
Copy the resulting Base 64 code into a calculated column or measure in the following format:
Name = “data:image/jpeg;base64, Base 64 Code”
Be sure to change the data category of your column or measure to Image URL. You can now view your images in a matrix or table visual, or a custom visual designed for displaying images.
Here’s an example I put together to demonstrate:
– Brian
e DNA Forum – Base 64 Image Solution.pbix (104.8 KB)
Hi @Akshay_05, did the response provided by @ankit and @BrianJ help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi @Akshay_05, we’ve noticed that no response has been received from you since July 7th. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Akshay_05, due to inactivity, a response on this post has been tagged as “Solution”. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the check box.
