Web.Content parameters from Postman dump
I got specifics from an API service I need to query (it’s an ML algorithm endpoint) in JSON exported from Postman. Nothing else but this is the documentation I can refer to.
I’ve been through Web.Content documentation in Microsoft (very poor indeed) this [link] also referred (https://eriksvensen.wordpress.com/2014/09/15/specifying-json-query-in-power-query-example-statistics-sweden/). This Chris Webb video warns me it a complex topic.
So my attempts stopped here. Is there any way to build the Web.Content call starting from a Postman export?
let
content =
““header””: [
““key””: ““request-source””,
““value””: ““mlaas-api””
““examples””: [
““Input1"”: ““The service(s) NETBACKUP PROXY SERVICE have been automatically restarted more than 5 times in a 24h period. Please investigate if this is expected behaviour.””
Source = Json.Document(Web.Contents(“https://fake.url.com/service/mlaas/classification/” & “dataModelId=175” & “apiKey=EE342B345-30B7-4023-FAFA-768A5CB3E0”, [Content=Text.ToBinary(content)])),
#“Converted to Table” = Record.ToTable(Source)
in
fake.postman_collection.json (1.3 KB)
Hi @Roberto , we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
after some trying, I got what I wanted!
In the header section adding the Content Type mad the trick.
Microsoft should add some more documentation to the Web.Contents function anyway.
Thanks All!
Roberto
body =
““examples””: [
““Input1"”: ““password reset””
output = Web.Contents(url, [Headers=[#"Content-Type"="application/json"], Content=Text.ToBinary(body)]),
Source = Json.Document(output)
in
Source
