I´m trying to connect to a web page with credentials, the only thing is that to access the web page I need 3 values, and Power BI Desktop (Get data from a Web) only gives you two values.
How can I connect Power BI Desktop to this web page using the three values?
Hi @Yeriel, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
I had the same situation once:
Go to Edit queries->data source setting , clear or edit this data source credential, select Basic from the window and type your username and password.
Then select the Extract table using examples : it will present an interactive window where you can preview the content of the Web page, and enter sample values of the data you would like to extract.
Try to create a new account in the website, if you don’t want to paste this url in the box : (Get data->Web(Basic)) , then select Anonymous .
Hi @Yeriel, did the response provided by @amira.bedhiafi.pro help you solve your query? If not, how far did you get and what kind of help you need further? If yes, kindly mark the thread as solved. Thanks!
