Water fall chart midyear summary
HI friends … i want to get midyear summary also in waterfall chart.
Actually i have a data in which data is starting from January and ending in dec. Normally waterfall chart will give me cumulative total at starting and end with details in between. I also want to see cumulative total in June as well for mid year audit. Please guide how it is possible…i will be highly thankfull.
regards
I guess the simplest way to achieve this would be:
Cheers
Pete
Hello @praveer82, good to see that you are having progress with your inquiry. Did the response from @BINavPete help you solve your inquiry?
If it does, kindly mark it as solution.
Hi @praveer82, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can create a new thread.
