I need help with the attached dataset. I want to show the result of the attached survey and provide the % and count for each category. Unfortunately, it doesn’t give me the correct figure, I think it’s because the table also count the blanks? What is the best and easiest way to visualise this on a bar chart?
Yes, this is the output I need. But is there a way to show the same without unpivoting the columns in the query editor? Can we calculate and show the same output through DAX formula?
If I unpivot, will it have an effect on the existing visuals and do I have to fix the calculations? I do have existing visuals and I am afraid that the result would change if I unpivot. Can you please advise/clarify?
As always, @Rajesh is spot on in his response. However, the DAX unpivot pattern is pretty cumbersome. I prefer to reference the table I want to unpivot in PQ (for example Sales), unpivot the table created and rename it (e.g. Sales Unpivoted), join it to my data model and work off the original or unpivoted version as needed.
