Visualizing movement of data
hello,
in the power bi report I have populated a table which shows movement of data as follows an dI wonder how I can display this graphically? any suggestions? thanks
previous_company previous_number current_company current_number
company_x 9786 company_b 6283
company_t 6754 company_w 5564
company_b 3456 company_U 7722
Sankey chart?
Chord chart?
All depends on how many different individual company numbers you are going to have?
Will thing happen with every single company?
Also, how is your data model set up?
thank you
Did my answer give you the solution @arkiboys ?
yes, thank you
Great, would you mind if you updated the thread so you apply the Solution to my answer please. Otherwise the solution will be added to your stats and not mine.
Thanks @arkiboys
Let me know how you get on.
