Visual Overlap - Scale Issue
Hi All,
I’ve found a problem when I overlap visuals. This is the scenario a Table and buttons with action bookmarks over the Table.
The problem is that when the User changed the Scale Monitor from 100% to another different the Buttons do not change the size as the Table does.
In Monitor 100%
In Monitor 150%
Is there any way to fix this issue rather that saying they user to always setup the monitor 100%?
Pbix from Data of a Workout to replicate the error pattern I have in a confidential report.
Visual Overlap.pbix (423.4 KB)
Santiago
Hi @scancela.90 - This seems like a default behavior of PBI and there might not be any solution for this.
Ankit J
Hello @scancela.90
Thank you
Hi @scancela.90
Due to inactivity, a response on this post has been tagged as “Solution”.
Hi @ankit
Thanks for you Reply.
Regards,
Santiago
