I am using multiple data flows in the reports I am creating. When I go into the Power BI Service I can use the lineage view to see which report connects to which data set and which SQL connection provides the data.
What is missing from this view is the dataflows that sit between SQL and the data set. It will show where there is a connection to SQL for some data but the reusable items come form data flows.
As I am looking to remove some dataflows that I hope are no longer used it would be good to see this information. Apart from editing all data sets is there another way to see this?
E
