Dear DNA team,
May I ask one question is there any way we can dynamically calculate the year variance between dates in the power query?
I prefer to write it in power query rather than writing DAX due to the business requirement. Your kind support will be appreciated.
In the picture, I was tried to divide by 365 but that is not giving me the accurate/correct answer for the special case such as “Leap year”. As you can seen in row 24, the answer supposed to be 1 as 2014 is leap year.
Hence, please help.
Myat
Hi @anonymous124,
See how this works for you. Just copy the entire script into a new blank query.
let
Source = Table.FromRows(
{#date(2023, 7, 31), #date(2023, 9, 1)},
{#date(2023, 9, 30), #date(2023, 9, 1)},
{#date(2024, 8, 31), #date(2023, 9, 1)},
{#date(2024, 9, 30), #date(2023, 9, 1)}
}, type table [Modified Date = date, Actual Starting Date = date]
fxYearVariance = (Date1 as date, Date2 as date) =>
Order = List.Sort( {Date.From(Date1), Date.From(Date2)} ),
Sign = if Date1 < Date2 then -1 else 1,
LeapDays = List.Count( List.Select(
List.Dates( List.First(Order), Number.From( List.Last(Order) - List.First(Order) )+1, Duration.From(1)),
each (Date.Month(_)=2 and Date.Day(_)=29) )),
Calc = Number.RoundDown( (Duration.Days( Date2 - Date1 ) + (LeapDays*Sign)) / 365 ),
YearVariance = if Calc >=0 then Calc +1 else Calc
][YearVariance],
t = Table.AddColumn( Source, "Test", each fxYearVariance( [Actual Starting Date], [Modified Date] ))
in
t
It returns this result.
I hope this is helpful
