I hope this is in the right place, but I have a new visual request and I’m a little stumped on how to get this calculation.
I have a model with labor tickets (manufacturing), shift hours, employee lists, and departments.
I have my average utilization measure by department looking good. However, how would I calculate utilization for the day across various departments? For example:
My default department is X (this department is in my employee table) so I apply half of my daily labor (per day) to my default department but I also clock labor to another department, Y.
So my utilization for that day would be X - 50% and Y- 50%.
I think my problem is the Department is on the Employee table, Department table, and Labor Table. When I try to pull in the average utilization as a value, the department from the employee table and the department from the labor table it isn’t able to split up the values. Any help would be greatly appreciated. Attached are some screenshots.
Hi @JamesT, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster. While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
When posting a topic with formula make sure that it is correctly formatted to preformated text </>.
Include demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details.
You can simply upload the file here or on cloud and share link. I can’t tell of any specific way to strip unnecessary or confidential data out. May be try putting some Dummy data.
Hi @JamesT , we’ve noticed that no response has been received from you since the 15th of May. We just want to check if you still need further help with this post? In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved. If you have a follow question or concern related to this topic, please remove the Solution tag first by clicking the three dots beside Reply and then untick the checkbox. Thanks!
Thanks to the contributors of this post. Due to the length by which this post has been inactive, we are tagging it as Solved. For further questions related to this post, please make a new thread.
