Hi @Tee1. Please upload your work-in-progress PBIX and a marked-up screenshot of the visual in question for your desired outcome, to help the forum members in their analyses.
Hi @Tee1, adding up to what @Greg mentioned above, we aim to consistently improve the topics being posted on the forum to help you in getting a strong solution faster.
While waiting for a response, here are some tips so you can get the most out of the forum and other Enterprise DNA resources.
Hi @Tee1, we’ve noticed that no response has been received from you since the 23rd of April. We are waiting for the masked demo pbix file, images of the entire scenario you are dealing with, screenshot of the data model, details of how you want to visualize a result, and any other supporting links and details. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
