Updated query
Hi @Melissa,
Thank you for taking the time to look on this. I have attached a sample pbix file.
My goal is to create a new column that extracts the names from the data, such as “John Legend” and “Ed Sheeran”. etc.
Sample.pbix (23.5 KB)
Hi @ronald_balza,
This syntax is invalid or no M code…
If you are unable to share an actual example please refer to this section: Item, Field Access, Lookup, Selection and Projection in the Power Query/M - Nested Structures course.
Hi @ronald_balza,
Give something like this a go
let
Source = Table.FromRows(Json.Document(Binary.Decompress(Binary.FromText("i45Wiq5+1DAnuCQxLe1Rw1wrMM/TBcQEMkwMTEzNgWwdINsvMTcVKuyVn5Gn4JOanpqXAhSp1UHRY2pmamhojKnJNUUhOCM1tSgxD6QntjY2Ji8mTylWB78LDI2MTUwxDXMpTVTwySxIBBtFlEHGpkYmWLwSkliZk1+kEFyemVaC6RegJqzWh2dkluSlVip45JcWl+SjeigWAA==", BinaryEncoding.Base64), Compression.Deflate)), let _t = ((type nullable text) meta [Serialized.Text = true]) in type table [#"Staff Name" = _t]),
GetNames = Table.AddColumn(Source, "Names", each
s = Splitter.SplitTextByCharacterTransition( {"A".."z", " "}, (x)=> not List.Contains( {"A".."z", " "}, x))([Staff Name]),
n = List.PositionOf( List.Transform(s, (y)=> Text.End(y, 4)), "Name", Occurrence.All ),
r = List.Transform( n, (v)=> Text.Remove( s{v+1}, {"”",":", "“"} ))
][r]
in
GetNames
Amend to your needs.
I hope this is helpful
Hi Ronald,
This is my way to solve this issue:
let
Names = Table.AddColumn(Source, "Custom", each List.RemoveItems(List.Transform({0..20},(x)=> Text.BetweenDelimiters([Staff Name],",“Name”:“","”",x)),{""}))
in
Names
I tried to use simple and short code but instead of the number 20, you can put a count of the maximum name in the text.
