Using Dax measures in rows on Matrix Visual
Good day team
I have created calculated dax measures which i would like to use in the Matrix Visual. They are all based on sales but group into categories, the dax returns values but i cannot use them in the rows of a matrix visual
Can you guide me?
Hi @neilonbooysen
Could you please share pbi file and show the issue :slight_smile:
Thank you,
Matty
@neilonbooysen,
In the matrix formatting options, under Values try turning on the Show on Rows option:
– Brian
Hi @neilonbooysen, did the response provided by @BrianJ help you solve your query?
If not, please send your masked PBIX file and let us know how far did you get and what kind of help you need further?
If yes, kindly mark as solution the answer that solved your query. Thanks!
Hi There,
Suggestion by Brian helped but not completely solved, I am preparing a data dump to share. Apologies for the delay.
