Hi, first time posting
I am trying to merge two tables in Power Query but I wish to use a conditional join to select which column should be used to complete the join
This is the idea I am trying to get to work. Where the secondary table has “Yes” in the Locked column, merge to the main table using “hsObjectId” in the main table else use “Joining HubSpot ID for Accept / Billing” in the main table to merge by using “HubSpot ID” in the secondary table in both cases.
This is my attempting use and if to control the which column to use, did work of course
#"Merged Accepted Data" = Table.NestedJoin(
#"Merged Closed Data",
if Table.SelectRows(#"Accepted Data", each [Locked] = "Yes") then {"Joining HubSpot ID for Accept / Billing"} else {"hsObjectId"},
"Accepted Data",
{"HubSpot ID"},
"Accepted Data",
JoinKind.LeftOuter),
can anyone assist? cheers
Hi @Charley194 ,
Welcome to the Forum.
Maybe you can first add custom column with this if then
= Table.AddColumn(#"Changed Type", "Custom_Merge_Column", each if [Locked] = "Yes" then [hsObjectId] else [#"Joining HubSpot ID for Accept / Billing"])
and then merge based on it ?
Best regards
How would I merge based on that return though?
If would like to merge data based on that new column you can use:
This is for merge if you just want to create a join - you can do it also but keep in mind that in one table that column need to be unique
More about this functionality you can find at:
https://app.enterprisedna.co/app/player-course/8?chapter=322&item=1255
https://app.enterprisedna.co/app/player-course/8?chapter=322&item=1259
if you need something more do not hesitate to ask.
Best regars
Hello @Charley194
Did the response from @mspanic help solve your query?
Thank you
Hello @Charley194
Just following up if the response above help you solve your inquiry.
If it did, please mark his answer as the SOLUTION.
We’ve noticed that no response was received from you on the post above. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
Hi @Charley194
Due to inactivity, a response on this post has been tagged as “Solution”.
We request you to kindly take time to answer the Enterprise DNA Forum User Experience Survey,.
We hope you’ll give your insights on how we can further improve the Support forum. Thanks!
