In PowerBi there is a Function called “USERPRINCIPALNAME”.
When put in a measure it gives you back in my case… “Chad.Sharpe@td.com”. It appears this function cannot be used in a calculated column.
Is there a way I can split this function so that I can
- Remove everything from @ onward
- Replace . with a space
The end result would simple be Chad Sharpe.
Without being able to transform it in PowerQ, I’m not sure who I would do it?
You’re correct that USERPRINCIPALNAME() is typically used in measures, not in calculated columns. But if you want to manipulate the string it returns in a measure to achieve your desired format, you can use other DAX string functions.
Here’s how you can do it:
- Remove everything from @ onward: The
LEFT() function combined with the SEARCH() function can help you achieve this. SEARCH() finds the position of one text string within another, and LEFT() returns a specific number of characters from the start of a string.
- Replace . with a space: The
REPLACE() function can help you achieve this.
Combining these, you can create a measure like:
Transformed UPN =
VAR UPNWithoutDomain = LEFT(USERPRINCIPALNAME(), SEARCH("@", USERPRINCIPALNAME()) - 1)
VAR Result = SUBSTITUTE(UPNWithoutDomain, ".", " ")
RETURN Result
In the measure above:
- The
SEARCH() function finds the position of the “@” symbol in the USERPRINCIPALNAME() result.
- The
LEFT() function then extracts all characters up to but not including the “@” symbol.
- The
SUBSTITUTE() function replaces the dot with a space.
If you used this with the example “Chad.Sharpe@td.com”, the result would be “Chad Sharpe”.
That’s Great!!!
You answered my question while I was still on the site looking around… lol
Always try to give you top service @chad.sharpe lol
