Based off a selection in an excel spreadsheet, I’d like my SQL in Power Query to be modified. The commented out section of query where I hardcode “108” works. Now, I need to get it working with a PPeriod_parameter. The error I get is directly below and seems to occur quite frequently if google is anything to go by. Does anyone have a suggestion as to how I can fix this error? In truth, I’m actually quite confused as to what the error even means.
And in Step-2(Source) please add double quote at end of the statement with & sign below for your reference. where PPeriod = " & PPeriod_parameter & ""]
Make sure your PPeriod_parameter should be of text as you want to input 108 which it will consider as number and you will get error then in that case you can use Text.From formula as below.
