Two badges aren't showing up correctly on main dashboard correctly
Hi @EnterpriseDNA,
Two of my badges aren’t showing up correctly on the main dashboard.
They are:
Paginated Report Writer II
Accessing Data via APIs in Power BI
I hope your team can research why it’s not showing correctly.
Sorry
Thanks for your help
Keith
@EnterpriseDNA
Can I please get an update on this one?
thanks Keith
Hi Keith,
You can find all of your certificates here:
On Demand Menu: Learning Center > Certificates
Can you check if the Paginated Reports and Accessing Data via APIs in Power BI do not show in this section?
Hi there
on the platform it doesn’t show the badge as per my screen print. If I click on one them it doesn’t show up properly like the others.
thanks
Keith
Hi @Keith,
Would like to check if this concern is already solved?
Thank you!
HI there,
This has been resolved.
Keith
