Hello I have this table here (in short because of privacy issue)
The gross margin column does not show the total the same as Excel - Power BI shows $5.9M while Excel shows $5.4M.
I tried using HASONEVALUE but it still does not work:
IT’s been several days and I still can’t fix it. Could you help? Thank you
Hi @ctvv3010,
I believe you have put HASONEFILTER on wrong column. I think it should be on item_group column instead of customer_group column? you can also test with HASONEVALUE to see if it works. BUT I am certain you are using wrong column in HASONEFILTER.
Please mark it solved if it solves your query.
Cheers!
In cases like this when posting in the forum, please add a sample PBIX file so we can better assist you. Sounds like you are going to possibly need the SUMMARIZE function so that you can get the correct total for your measure. You can also you the search feature at the top right of the screen to see if something similar has been asked. In your case, this is a very common question. Here is a video from Sam to point you in the right direction, If you need further assistance, please post a sample file.
Thank you for your help! I solved it by using different sets of formulas to calculate profit/margins, thanks to Sam’s videos
Please share your results, you never know who this might help in the future!
