The Total is not coming correct. All the columns are coming from different tables. A quick help is needed here if you see the screenshot below the expected output total is 2 but I am getting 4. Attaching pbi file as well for the solution
Calculation issue.pbix (255.3 KB)
Here is my measure which I wrote:
Weighted Velocity =
VAR TotalActualValueTasks = SUM(‘Tasks’[ActualsValueSum])
VAR TotalActualValuePrimaryWorkItems = CALCULATE( SUM(PrimaryWorkItems[ActualValue]) )-- this portion needs adjustment DIVIDE(TotalActualValueTasks, TotalActualValuePrimaryWorkItems) * TotalStoryPointsPrimaryWorkItems
VAR TotalStoryPointsPrimaryWorkItems = SUM(Tasks[ParentEstimate])
Good afternoon @AlexBehrmann
Welcome to the forum.
It is a known problem that measures not always total correctly.
Greg Philps has written an extensive post about how to fix the problem Fix Incorrect Totals
Solution included in attached PBIX
Calculation issue WeightedVelocity v2.pbix (262.4 KB)
The weighted Velocity is calculated correctly in the table Tasks, but is not forced to calculate for the totals, this can be fixed by adding a sumx measure, in this case
Weighted Velocity CorrTot = SUMX( Tasks, [Weighted Velocity])
which forces the calculation also to calculate the measure for the totals.
P.S:
- adding the Sumx to the Velocity measure itself does not give the desired result
- using PWI Actual Value2 = CALCULATE(SUM(Tasks[Task ActualsValueSum])) instead of PWI ActualValue = Tasks[ActualValue] has the advantage that it gives the total of the column.
Hope this helps you further,
Kind regards, Delta Select
Hello @AlexBehrmann
Thank you
Hi @AlexBehrmann
Due to inactivity, a response on this post has been tagged as “Solution”.
Thank you so much that worked. Appreciate you help.
