Hi
Thanks to JBolcher I have my contracts forecasting out at the line level based on the [Forecast?] field being set to “Y”
The issue I am facing is that I need to be able to summarize this by Customer and Contract but when I try to do this the values are incorrect
2022 Forecast should = £2,312 not £2,408. When placing the measure just with the customer or just the contract it appears to be assuming everything is a forecast?
To fix the totals you just need to write a small measure and you’ll see that all the visuals will get fixed and will start reflecting correct grand totals. Below is the measure alongwith the screenshot of the final results provided for the reference -
I’m also attaching the working of the PBIX file as well as providing a link below of the post which one of our expert had created which specifically addresses this type of issues.
Note:In order to view the entire post, please click onto the link and not onto the “expand/collapse” button.
Hello @AliB, just following up if the response from @Harsh help you solve your inquiry?
We’ve noticed that no response has been received from you since November 1. In case there won’t be any activity on it in the next few days, we’ll be tagging this post as Solved.
