I have tried my best to locate a GEOJSON code for Christchurch, New Zealand (one that can be used by the Shape Map visual in Power BI Desktop), without any success.
There have been a few related treads in the Forum, but none clear enough for Christchurch.
Does anyone have the Json code, please? If not, could you please suggest the steps I should take to create one?
No, @ektx answer did not solve the problem, but offered the solution for the second step I need to take.
I believe, the first step is to identify the proper dataset (from https://catalogue.data.govt.nz/), then use mapshaper.org to convert iit to GeoJson (if it has not already been converted) for the purpose of using it with Shape Map in Power BI.
I will try to find this dataset when I have a bit of time and advise as such.
I hope you are doing well. I was wondering if it would be possible for us to close this thread temporarily while you are trying out the solutions provided above. Once you have made progress and require additional support, feel free to open a new thread and reach out to us again.
Thank you for your understanding and I look forward to assisting you further in the future.
