Topic on DAX generator
Can you guide us how to use DAX generator?
Hi @UmaSuresh … I’ve been immersed in the Power BI community/universe for a few years now, but don’t recognize “DAX Generator”. Can you please provide specifics to which (part of) tool this refers?
Dear Mr.Greg
I got a link today on this, hence asked about this :
The Fast DAX in the world - Introducing DAX Genera… -
(https://community.powerbi.com/t5/Webinars-and-Video-Gallery/The-Fast-DAX-in-the-world-Introducing-DAX-Generator/m-p/2153835)
Hi There
That link isn’t done by EDNA community but it was developed my Power bi Tips Community by Mike Carlo (powerbi.tips)
Mike has some great knowledge also related to Power BI
I hope this helps.
Keith
Hello @UmaSuresh, good to see that you are having progress with your inquiry. Did the responses above help you solve your inquiry?
If it does, kindly mark as solution the answer that solved your query.
Hi @UmaSuresh, due to inactivity, a response on this post has been tagged as “Solution”. If you have any concern related to this topic, you can create a new thread.
