Top N Filter when drilling through hierarchy
Is there any way to maintain a “Top N” filter so that when drilling through the hierarchy, you only see the top N number of rows? In the attached example, I have a matrix with County and the user can drill down to city. I set a filter to top 5 counties, but when a user drills down to city, I would like them to see the top 5 cities. Applying a top 5 filter to city doesn’t work because then only the 5 cities are included when viewing by county.
The reason why I want this functionality is to limit the amount of rows in a table so that a very long list of rows doesn’t take a long time to load.
Free training Power BI Demo.pbix (506.1 KB)
Hi @Eric,
Thanks for providing a sample file :+1:
Can you see if this works for you.
Top5 By Country/City =
VAR TopFiltered =
    CALCULATETABLE(
        GENERATE(
            VALUES( Location[County] ),
            TOPN(
                5,
                CALCULATETABLE( VALUES ( Location[City] ) ),
                [Total Profits]
        ALLSELECTED()
IF( NOT( ISINSCOPE( Location[City] )), [Total Profits],
    CALCULATE( [Total Profits],
        KEEPFILTERS ( TopFiltered )
Here’s your sample file. eDNA - Top5 Country by City.pbix (502.8 KB)
I hope this is helpful.
Wow that’s brilliant! Thank you!
@Melissa If I could ask a follow-up question, what if I wanted to add another level to the hierarchy, such as customer name, and also limit that to the top 5 customers? In the attached workbook, I added customer name under city. Is that also possible?
I’m assuming that again you don’t want filtering on the City aggregate level for only Top 5 Customers
VAR TopFilteredCity =
    CALCULATETABLE(
        GENERATE(
            TOPN(
                5,
                [Total Profits]
        ALLSELECTED()
VAR TopFilteredCustomer =
    CALCULATETABLE(
        GENERATE(
            VALUES( Location[City] ),
            TOPN(
                5,
                CALCULATETABLE( VALUES ( Customer[Customer ID] ) ),
                [Total Profits]
        ALLSELECTED()
    IF( NOT( ISINSCOPE( Customer[Customer Name] )),
        KEEPFILTERS ( TopFilteredCity )
        KEEPFILTERS ( TopFilteredCustomer )
Hi Melissa, appreciate for your expert level response though I want to get dynamic top N filter for all three categories. Hierarchy level of mine is different but you may share the logic using the same country > city > customer name scenario.
Hi @Susanta1991,
Welcome to the forum, glad to have you here!
Please avoid asking questions in a Solved thread, instead create a new topic and refer to this one. Thank you.
Hello @Melissa,
Thanks for the response, will surely create a new thread asking the same query with share background data. cheers.
