Hi all,
After setting up a model exactly like a previous one, I can’t get my Tooltip to show filtered results when hovering over a table value. In older BI versions there was a knob for that but I can’t seem to find anything similar.
Do you mind taking a look pls?
@Thimios To filter the Tooltip you need to make sure that Supplies table is able to Filter the Supplier Pricelists table. Either enable Bi-Directional relationships or use CROSSFILTER inside CALCULATE.
