Hi @lancemillercpa98.
How’s this?
To implement, just add a tooltip block to the encoding block and reference the plan and value fields.
To perform in-visual calculations for the variance and % variance, add a transform block then expand the tooltip encoding block as desired.
"data": {"name": "dataset"},
"transform": [
"calculate": "datum['Value'] - datum['Plan']",
"as": "_variance"
"calculate": "datum['_variance'] / datum['Plan']",
"as": "_percent_variance"
"encoding": {
"x": {
"type": "quantitative",
"scale": {"nice": false},
"title": null,
"axis": null
"layer": [
"mark": {
"type": "bar",
"color": "#ccc",
"size": 40,
"yOffset": 10,
"tooltip": true
"encoding": {
"x": {"field": "Plan"},
"y": {
"field": "",
"title": null
"mark": {
"type": "bar",
"size": 20,
"yOffset": 10,
"tooltip": true
"encoding": {
"x": {
"field": "Value",
"title": null
"color": {
"condition": [
"test": "datum['KPI'] === 2",
"value": "red"
"test": "datum['KPI'] === 1",
"value": "yellow"
"test": "datum['KPI'] === 0",
"value": "black"
"value": "green"
"tooltip": [
"field": "Plan",
"formatType": "pbiFormat",
"format": "#,#"
"field": "Value",
"format": "#,#"
"field": "_variance",
"title": "Variance",
"format": "#,#"
"field": "_percent_variance",
"title": "% Variance",
"format": "#%"
"mark": {
"type": "tick",
"color": "orange",
"size": 50,
"yOffset": 10,
"thickness": 2,
"tooltip": true
"encoding": {
"x": {
"field": "KPITarget Value",
"title": null
"mark": {
"type": "text",
"color": "orange",
"dx": -5,
"dy": 0,
"xOffset": 0,
"yOffset": 50,
"angle": 0,
"align": "right",
"baseline": "bottom",
"fontSize": 14,
"fontWeight": "normal",
"limit": 0
"encoding": {
"text": {
"format": ".2s"
"x": {
"mark": {
"type": "text",
"dx": 0,
"dy": 0,
"xOffset": 0,
"yOffset": -40,
"angle": 0,
"align": "right",
"font": "sans-serif",
"fontSize": 20,
"fontStyle": "normal",
"limit": 0
"encoding": {
"x": {
"aggregate": "max",
"field": "Plan",
"text": {
"field": "Actual",
"format": ".2s"
"mark": {
"type": "text",
"dx": 0,
"dy": 0,
"xOffset": 0,
"yOffset": -40,
"angle": 0,
"align": "right",
"baseline": "top",
"fontSize": 14,
"limit": 0
"encoding": {
"x": {
"aggregate": "max",
"field": "Plan",
"text": {
"field": "Format Variance"
Hope it helps.
eDNA Forum - Deneb Tooltip Formatting.pbix (2.5 MB)
